Proportioning valve bypass, to stalling converter at the track.
Old Aug 20, 2002 | 02:08 AM
kclarson's Avatar
Post Proportioning valve bypass, to stalling converter at the track.
Hello,
I am curious about bypassing the proportioning valve to the rear brakes with a normally closed solenoid valve. This will give me full rear brake pressure allowing me to stall up the converter, when I activate the solenoid with a momentary switch. Currently I can stall to about 2100 RPM in a 97 Camaro with a 2800 converter.
Anyone done this mod? If so where can I get the parts? I can deal with the wiring and the brake lines, but where can I find the solenoid valve that will work with an automotive brake system and work with 12 volts? Any ideas or information would be appreciated!
Courtney
Old Aug 20, 2002 | 03:30 PM
Shon Herron's Avatar
Post
Try these guys:
www.ronscustomauto.com
they did an article in GMHTP and I talked to them at length. I am going to try my TC out first before doing this mod but it sounds alot better than a Tbrake, this is a buick turbo trick that has been out for a while.
let me know if it works.
Old Setup was:
94 Z28 A4(3.73)
LT4 H/I/HOT cam
1.69/12.27@108
Old Aug 20, 2002 | 07:47 PM
OneFlyn95z28's Avatar
Lightbulb
Biggest problem would be the ABS system. But I guess if you dump it(the ABS) you should be fine
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
Old Aug 20, 2002 | 08:28 PM
Stephen 87 IROC's Avatar
Post
Vehicle brakes will not hold a car to the converter's full stall. They just can't hold back the torque put against them. The only way you can go to full stall is with a transbrake. By locking 2 gears at once there's no way for power to go out of the tranny.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.418
Best MPH on a time slip: 117.01
Best corrected ET: 11.051
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.595
Member of the Calgary Drag Racing Association
Old Aug 20, 2002 | 11:11 PM
mod313's Avatar
Post
Easy mod is to do away with the prop valve entirely and go with largest dia piston manual m/c you can find to fit, usually s10, and if rear drums get the larger wheel cyl's.
This set up holds great on line and you can usually stage at higher rpm's. bBut like what was just said, staging rpm's and stall speed will never equal on a footbrake car.
Old Aug 22, 2002 | 03:59 PM
kclarson's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Shon Herron:
Try these guys:
</font>
Yes,
That is the same article I saw. I think it would be a good mod. I will try it. Thanks for the reply.
Courtney
Old Aug 22, 2002 | 04:04 PM
kclarson's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by OneFlyn95z28:
</font>
I don't think it will bother the ABS. ABS does not monitor fluid pressure to the rear brakes. I works off the front and rear wheel sensors. I am not positive about that but will do the research to find out.
Courtney
RUENUF
Mar 13, 2016 03:39 PM
marine1bird
10
Jan 25, 2015 12:02 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
mysticslp2002
Jul 29, 2002 02:03 PM
