Need some suggestions
Old Apr 18, 2007 | 02:54 PM
ChevyTuffD.A.'s Avatar
I just got my UMI lower control arms in the mail today. I want to install them ASAP but I dont have a flippin grease gun. Do you guys have any ideas on what I should do about getting these things greased?? Thanks, Dustin.
Old Apr 18, 2007 | 03:25 PM
2000GTP's Avatar
Don't they come with packets of grease to do the install with? My Spohn arms did, I liberally lubed them up and then followed up with a grease gun.
Old Apr 18, 2007 | 04:21 PM
They did come with a packet of grease, but you need a grease gun for the zirk fittings on each end, which I dont have.
Old Apr 18, 2007 | 05:40 PM
2000GTP's Avatar
Just pick up a grease gun, you can get them at just about any auto parts store and they are not very expensive.
Old Apr 18, 2007 | 05:45 PM
My first course of action is going to the local performance shop and seeing if they can hook me up, even if it cost me a couple bucks. If that doesnt work out then I might have to just go buy a grease gun. 2000GTP, are you stalking my threads??? You seem to find every one of them. Im j/k I appreciate your help.
Old Apr 18, 2007 | 06:34 PM
2000GTP's Avatar
Be sure that if you go to a shop and you have the poly ended lca's, they use the silicone based synthetic grease, not the traditional petroleum based grease.
Old Apr 18, 2007 | 07:02 PM
In the instructions they sent me, it says to use a non-lithium grease, it also said they recommend marine grade because water will not wash it away.
Old Apr 18, 2007 | 11:52 PM
You can get a mini grease gun and small cartidges of the correct grease for a few bucks at any auto parts store. Why would you rather pay a shop to grease a few fittings, when you could get the gun for a few bucks, and be able to grease them whenever you feel like it?
Old Apr 19, 2007 | 07:10 AM
I guess I didnt realize how cheap it is to just get a grease gun. Probably what I will end up doing. Also, at first for some reason I was thinkin I could grease them before they were on they car and just take the arms up there and ask them to help me out. But now that I understand they have to be grease AFTER they re on the car, that changes things. Can you tell I dont know crap about suspension components?
Old Apr 20, 2007 | 01:58 PM
krazykorean35's Avatar
i jus got my umi lcas 2 and ive never done ne suspension work myself, chevytuff id appreciate any update on how the install went etc
Old Apr 20, 2007 | 04:49 PM
I havent done much suspension work before. Heck, the first time I ever touched the suspension was when I removed my rear axle to install my gears. It was pretty easy, only took me about 1 1/2 hours by myself. I have not installed mine but it is a pretty straight forward install. Take out 2 bolts, drop the old one, pop the new one back in. Do it 1 at a time tho so that the axle doesnt move too far on you. Also, the bolts might be pretty hard to get off so its prolly gonna take some force. Thankfully I had to break mine loose when I took my axle out so hopefully they wont be too bad.
Old Apr 20, 2007 | 05:35 PM
2000GTP's Avatar
PB Blaster and a breaker bar will be your best friend.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
