Need some rear Drum brake removal tips
Old Nov 25, 2005 | 12:09 AM
RobZ's Avatar
Question Need some rear Drum brake removal tips
Sorry Could't find an appropriate place to place this problem that I need help.
Sure seems I can't find a definate web page tutorial on how to take this Drum brakes off.My buddy needs help on taking off the drum brakes off a 91 GM 1/2 4X4 and we looked for the small insert in the backing plate to insert a flat screw driver to push off the drum,but seems theres isn't any one visible.Disc's I know how to do,but these weird drum stuff I taught I knew.Any thoughts on where to look?Thanks
Old Nov 25, 2005 | 04:51 AM
TheNovaMan's Avatar
Re: Need some rear Drum brake removal tips
This is what I hate most about drums. Loosening the adjuster might help, assuming there is a slot on the drum, but you might have to resort to a pry bar and a BFH. Stick the pry bar between the outside edge of the drum and the backing plate, and hammer on the pry bar (prying doesn't usually help much).
Old Nov 25, 2005 | 02:09 PM
OBE1 95Z28's Avatar
Make sure the emergency brake is off. A lot of drums have 2 threaded holes on the front that can be used to "jack" the drums off. They're approximately 1/4" in diameter.
Old Nov 25, 2005 | 04:26 PM
respectirocz's Avatar
my drums were rusted to my hubs
i needed a bfh and about a half hour of banging on the front of the drum
i thought banging from the inside would help get it off, but banging on the outside was easier and more effective
anyway first determine what the problem is
make sure the e-brake is off of course
if the drum slides out about a quarter inch then u need to adjust it
what happens is as the shoes wear, so do the drums, you create a little ridge in the drum, and the shoes have adjusted themselves so far out that they catch the ridge
if it doesnt move at all, not even a quarter inch, then the adjustment is not the problem (yet) and i go back to the first statement, using a bfh to break the rust loose
you could heat up the drum (be sure not to heat up the hub as much) but i'm not a big fan of heat
Old Nov 25, 2005 | 11:21 PM
RobZ's Avatar
Thanks for the help.Im still a little cautious,but If banging will do I think ill try that.Funny I told my buddy it had a slot in the back plate and told him we just needed to drive a flat head and push it in there.Hammer the Flat head and that would be it.So after viewing the old back I found none.So I left it alone but will try to bang it out.
Jan 3, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
bossco
Nov 29, 2014 10:18 AM
