My rear is bouncing going over bumps???
Old Jan 3, 2005 | 09:09 AM
camaro 22's Avatar
Question My rear is bouncing going over bumps???
When I go over a bump, or riding on a brick road, the right rear wheel or somewhere around there is loose and is just bouncing. I can't describe it really any better. I thought it was my lower control arm loose at the subframe connector because this has happened before, but I tightened using my car jack on the socket wrench for torque, but it's still loose. Anyone have any clue what the problem could be? TIA.
Shawn
Old Jan 3, 2005 | 11:16 AM
Re: My rear is bouncing going over bumps???
Bad shocks.
Old Jan 3, 2005 | 11:19 AM
camaro 22's Avatar
I don't think that's it. If I push down on the car it seems fine. It's only on the right rear side and sounds as if something is loose. Thanks for the reply. The shocks only have 25k miles by the way.
Old Jan 3, 2005 | 11:20 AM
camaro 22's Avatar
You got me thinking now though that maybe it's the shock bolt to the frame.
Old Jan 3, 2005 | 02:45 PM
wbna0149's Avatar
Right rear you say, Might check the exhaust as it goes over the axle
Old Jan 4, 2005 | 01:11 AM
Severous01's Avatar
yeah, i had to bend part of the body up in there. there is a piece that the rear quarter welds to the t-top storage area...yeah, i put some vice grips there and wrenched it towards the wheel. it stopped the rattle until it got really cold and the tips touched. but it stopped the rattle for a while
PublicEnemy1
Apr 7, 2015 12:21 PM
jj71787
Jan 31, 2015 10:20 PM
Jazsun
Dec 29, 2014 12:14 PM
ModdedNerd
Dec 25, 2014 05:51 PM
