my brakes picked a fight with my welds
Old May 1, 2004 | 01:04 PM
sniffin94's Avatar
I have 15x9 welds on the back of my car time to do the brakes, no problem get it all back toghether and the rear calipers rub onthe wheel. Must be the new pads spaced the caliper just enough to rub. Time to bust otu the grinder and go off on these calipers. Never can go perfect
Old May 1, 2004 | 04:23 PM
OBE1 95Z28's Avatar
Your exactly right...the wider pads changed the clearance.
Old May 1, 2004 | 07:15 PM
Xride's Avatar
how much are you going to have to grind off your caliper?
must be some real tight clearence, and with only one hitting is it bent a bit?
Old May 1, 2004 | 07:22 PM
sniffin94's Avatar
no both of the back ones were grinding, I had the same problem on the front until I ran spacers. All I did was grind the fins off of the back of the caliper. Not the whole fin but probaly 1/8". Works fine now but an unexpected problem. I hate that just changing pads and some cross drilled rotors turned into a haedache. Oh well it's done now. Time for some beer
HarleyZ28
Oct 5, 2015 06:23 AM
4586
Apr 29, 2015 01:43 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
QuickSilver02
Apr 7, 2015 11:12 AM
siguy
Nov 27, 2014 10:07 AM
