motor sits 1in back after bmr sbc swap
I put an bmr k-member 4 the sbc conversion in my 02 trans am. After dropping the motor and trans in the trans mount is 1 inch off from lining up with the crossmember. The motor needs 2 come up1 inch towards the front of the car for mount to work. Also the drive shaft is pushed all the way 2 the tail shaft on trans. I measured my friends car with a carbed lt1 and his motor sat exactly 1 inch farther up than mine. Does anyone no if there are problems with the bmr member?also the motor needs to come over towards the driver side about a half inch to make header fit around steering arm.Any ideas on what I can try?
Have you contacted BMR? Their customer service is pretty good
Edit: http://www.ls1tech.com/forums/showthread.php?t=729585
jb4xx
Feb 2, 2015 10:00 PM
