Is an LT1 to C5 brake conversion possible?
Old Nov 29, 2005 | 11:41 PM
Skull Leader's Avatar
Question Is an LT1 to C5 brake conversion possible?
It seems like you could just bolt the C5 adapter bracket to the spindle if the spindle itself is modified (cutting sides off) as seen here:
I figure I'd start from scratch instead of buying a whole "kit" with used rotors and hubs I don't need. Thoughts?
Old Nov 30, 2005 | 12:09 AM
scottslt1z28's Avatar
Re: Is an LT1 to C5 brake conversion possible?
yes it is possible
Old Nov 30, 2005 | 04:38 AM
5.0THIS's Avatar
I'm not sure I understand your question. You're looking at a picture of it having been done. That's always how it's worked with the adapter brackets. You dont buy a kit with hubs, at least I've never seen one. The only kit I bought, besides Bishop's brackets, was all the other parts I did need (rotors, calipers, abutment brackets, sliders, hardware, etc.)
Old Nov 30, 2005 | 08:15 PM
Lightbulb Re: Is an LT1 to C5 brake conversion possible?
Maybe I should have specified that picture above is of an LS1 spindle.
Old Dec 1, 2005 | 02:26 AM
5.0THIS's Avatar
Ok, and? It doesnt matter, LS1 or LT1 spindle. Any adapter bracket will work on either, the only difference is how much of the spindle you have to cut off.
Old Dec 1, 2005 | 09:24 PM
NOSCaMaRo's Avatar
Yes, the LT1 spindle has 2 ears to cut off while the LS1 is only one. The first step in UMI's instructions says this- http://www.umiperformance.com/c5conv.aspx
I have done installs on both cars, its the same.
Old Dec 1, 2005 | 09:53 PM
dhirocz's Avatar
Yes, and it ROCKS...I have one with C5 calipers, slotted rotors and Z06 pads and I love it. Cool thing is that I heard the C6 14" brakes bolt right on C5's... meaning they'll bolt to our adapter brackets as well. Guess what I plan on doing...
Old Dec 2, 2005 | 12:18 AM
5.0THIS's Avatar
Hope you got 18 inch wheels.
Old Dec 2, 2005 | 12:22 AM
dhirocz's Avatar
I will when I change my wheels within the next few months...
now it should be called the C5/C6 brake conversion
Old Dec 2, 2005 | 02:14 AM
5.0THIS's Avatar
To my knowledge, nobody has stress tested Bishop's brackets with a C6 setup. You're looking at higher loads on the bracket with the calipers out that much further.
Old Dec 2, 2005 | 08:42 AM
dhirocz's Avatar
True. But as stout as those pieces are, and as much overkill on strength as they are claimed to have, makes me alot more comfortable on using the C6 brakes with them. I wouldn't consider them with some of the cheaper brackets out there. Maybe I'll drop bob a line and see what he thinks.
As good as the C5 brakes are, I would assume that the brakes would lock up the wheels before damaging the brackets even became a concern. I'll post the results.
ddr698
Jan 9, 2015 10:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
vals95z
Mar 18, 2003 03:45 PM
