LS1 Steering Shaft Swap
My g/f bought me an LS1 steering shaft to replace the LT1 shaft a couple weeks ago when I was looking for more clearance between headers and steering shaft. Well, I'm noticing that the steering is feeling somewhat loose which I believe is the rag joint showing its age (from what I've read and heard). So, since I have an LS1 shaft, which has no rag joint, I'd like to swap it in.
My question is how hard would this be? I read on another forum that an alignment would badly be needed, but am not sure why. Can anyone shed some light on this? Would it just be a front-end alignment (wheels) or something else? Thanks in advance everyone.
I have read that the orientation is a tad different on the LS1 shaft and the steering wheel will be off center. It will not affect alignment. Maybe it will maybe it wont but you will need to turn tie-rods to re-center the wheel if if happens.
Being the OCD freak and reformed crackhead
I am it drives me insane if my steering wheel is the slightest bit off center going down a straight road.
Thanks for the replies everyone. So, what would I need to do if I do this swap? Just pull the steering wheel off and change it? What about the internals for the steering column (SIR parts and such)?
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
