ls1 brake upgrade
Old 05-29-2012, 09:02 PM
mab6680's Avatar
ls1 brake upgrade
just did a ls1 brake upgrade on my 97 lt1 took about 2 hours i changed the ball joints while i had everything apart well worth it huge diff in stoping power and i painted the calipers red looks great behind the zo6 wheels
mab6680 is offline
Old 05-30-2012, 04:14 PM
transamtom's Avatar
Re: ls1 brake upgrade
Yes the difference is quite noticeable,I did the conversion on my 94 TA way back in 2000.
I have 99 TA and 01 V6 Bird now so I kind of take good brakes for granted now.
transamtom is offline
Old 05-30-2012, 04:30 PM
mab6680's Avatar
I was rather surprised after I had all raybestis advanced technology rotors and pads all the way around and the braking still sucked
mab6680 is offline
Old 06-02-2012, 10:05 AM
96m6lt1's Avatar
When I did my brake conversion I had read a bunch about the rears do not make a big difference and the.are not worth it to swap....... Well, I am glad I swapped the brakes in stages!
For me I did the rear first and immediately I noticed a HUGE difference in stopping force coming from the rear so the next week I swapped the front and WOW the smile on my face spoke......
Of course me being the spirited type of driver I had to put them to the test 100+ MPH to 0 was MUCH much better. Once this swap is done it will let you know right.off the bat GM put too small of brakes on our Lt1 cars..... I never once had a problem with my Lt1 brakes either they just were not efficient enough for my kind of driving.......
96m6lt1 is offline
Old 06-02-2012, 11:08 AM
mab6680's Avatar
I only did the fronts but now I want to do the rear brakes too what's involved in the rear conversion and what parts are needed I have the itch now
mab6680 is offline
Old 08-11-2012, 05:56 PM
parkers Z28's Avatar
I would also like to up grade my brakes does someone have a link to how this is done ??
and what I need ??
parkers Z28 is offline
Old 08-12-2012, 03:30 PM
Ok the only thing that i really need to is with the larger brakes and stuff i will also need
the ls1 brake booster right ??
Old 08-12-2012, 07:38 PM
crazypurgatory's Avatar
Lightbulb Re: ls1 brake upgrade
From what I remember you need the axles from the 98-02 camaro along with all the hardware, brackets and cables.
Then axles are a little longer because of the parking brake shoes.
The ports on the 98-02 master cylinder are a different size so you won't be able to use it with out I would think replacing all the lines or at the very least the rear.
Hopefully somebody will chime in about using the master cylinder out of the 98-02 camaro.
crazypurgatory is offline
10-31-2016 11:09 AM
R@mpage
04-20-2015 10:02 AM
Jazsun
12-29-2014 12:14 PM
Quick Reply: ls1 brake upgrade
