Loosing traction on corners...(98z)
What's the biggest culprit of loosing traction when taking corners? I can think maybe of the following:
shocks
springs
LCAs
Are those culprits and if so how would one rank them?
Anyway, I find that I can't be very aggressive on the throttle cornering or one of the wheels may slip. Also I changed my shocks out recently for the 'high-end' utozone garbriel shocks recently, however I think I had issue before that (yes I know they're not the best shocks). Anyway, I'd like to get this under control.
Any tips on what to look for. Oh BTW, I have poly endlinks and bushings on the rear. Everything else is stock except the rear shocks as I mentioned.
shocks
springs
LCAs
As for tires I got the Firestone Firehawks...
BTW, I think I just solved the problem. I used to get my car serviced at the dealership which including checking tire pressure. About a year ago I just started going to a local oil change place. Well lo and behold, the pressure on all 4 tires were low and low by the same amount! It's rainy now so I can't test it out, but I bet that's it.
This slipped by me because I used to check the pressure all the time and it was always 30 PSI (thanks to the dealership), but stopped doing it.
How bad can they be? If they're that bad, I may go ahead and order some bilsteins or something else later on. The rear of the car doesn't bounce when I push it down so they were doing at least a good of a job as the old stock ones, so I'm in no hurry.
The firehawks have about 30k on them. To be honest handling or traction wise, I didn't see a huge edge over the goodyears that came with the car stock, but I wanted to try them anyway a couple years back since they got such high ratings on tirerack.com.
I also found that my PHB helped 'sway out' as I call it on bumps in corners.
Firehawks are not the best tires...And as far as bilstiens go.... I have them. If I try to jounce my suspension, it's stiff as h3ll. But it rides great! w/ the Eibach springs too. (I think they're revalved SLP Eibach's)
I was going to say tire pressure, but you already nailed that one. I adjusted mine from 26psi to 28 psi and I get squirley too easily now. Especially on a 35 sidewall.
I wish I could answer your question. I can't, not given the information here. I'm completely unclear if you are getting:
Fine steady state balance, but power oversteer?
Loose in steady state cornering or not?
If fine steady state and not purely a power oversteer issue, is it bumps that cause the rear to move?
When the rear moves just it do so in a "jittery" fashion, or just slide?
When the rear moves is it because you just spun the hell of one tire (weak LSD which makes for nasty oversteer)?
All I'm saying it what you have there is like telling your doctor you're coughing. It's not enough to go on. What's worse is suspension tuning is much more complex than any other single part of the car since there is overlap (but not the same reactions) from many parts.
