Lift in the rear on launch
Old Jan 21, 2008 | 04:07 PM
Sweetred95ta's Avatar
I bought a Ford 9" that utilizes lift bars instead of a torque arm. I understand they're called lift bars, but I think the car is lifting so much, that I'm losing traction (1.75 60 ft.). I have a picture somewhere of what the bars look like, but basically, for those of you that don't know what I'm talking about, they're bars that connect from a drop bracket under the LCA (where it bolts to the rearend) to the front of the LCA. This forms a triangle and makes the pinion angle adjustable. The pinion angle is something else I haven't messed with. I thought I read somewhere that you can get chain limiters for the back. Is this the solution? Or, should I just deal with it and know next time to not try and bypass the torque arm? Just taking off, I can feel the car lift before it moves. Here's a pic of the car on launch. Completely stock suspension except for Lakewood LCA's in the rear. What do you guys think?
Click to enlarge
Click to enlarge
RUENUF
Mar 13, 2016 03:39 PM
kandied91z
Jan 23, 2015 11:14 AM
mark0006
Dec 25, 2014 09:50 PM
bossco
Nov 29, 2014 10:18 AM
squarehead
Nov 21, 2014 08:02 PM
