lca relocation bracket question
Old Mar 11, 2006 | 07:16 PM
OutlawLS!'s Avatar
Question lca relocation bracket question
I just got these lca relocation brackets , bolt on .
Do I need to modify/cut anything to get them to fit? Or do they just squeeze inbetween the metal pieces where the old ones used to go?
Thanks in advance.
Old Mar 11, 2006 | 07:52 PM
Re: lca relocation bracket question
They should mount "over" the stock brackets, from behind, with the tab for the bolt hole over the stud for the shock.
Old Mar 12, 2006 | 11:14 AM
Bud M's Avatar
Nope, no modifying is necessary, just unbolt the LCAsa and lower shock mounts and bolt them in.
Didn't they come with instructions?
Old Mar 12, 2006 | 03:22 PM
OutlawLS!'s Avatar
No instructions, got them off of J & M products.
I've seen some pics of some installs and it seems some people cut off the part of the brace that is over the original brackets.
That is why I am asking cuz I can't get them to fit right.
Thanks.
Old Mar 12, 2006 | 08:09 PM
hotpart's Avatar
Former Vendor
Instructions have been email to you.
Old Mar 12, 2006 | 09:12 PM
OutlawLS!'s Avatar
thanks for you help.
Old Mar 12, 2006 | 10:04 PM
teke184's Avatar
there is a thin metal bracket...for the brake lines if i remember correctly...that has to be removed and trimmed.
that was the only "modifying" that i had to do for my BMR brackets
94B&RZ-28
Dec 22, 2008 10:00 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Waste
Jul 31, 2002 11:59 PM
twistedwedge
Jul 27, 2002 01:54 PM
