Lakewood traction bars
Old Nov 21, 2009 | 06:30 PM
DEEZNUTZ's Avatar
i have a 94 z28 and was considering giving these a try. i have m/t drag radials and umi three point sfc"s. everything else is stock with poly bushings.
the bars are 300 bux. anyone have/tryed these? if not, which suspension component would help with traction the most/bang for buck? thanx
Old Nov 21, 2009 | 10:41 PM
Best solution is a pair of tubular LCA's and LCA relocation brackets. They can produce 1.2x 60-ft times in high HP 4th Gens. No need for the complication and cost of the Lakewoods. I've seen a few reports of the Lakewoods tearing themselves apart, due to suspension bind.
http://www.spohn.net/shop/1993-1997-...-Control-Arms/
http://www.spohn.net/shop/1993-1997-...tion-Brackets/
Old Nov 23, 2009 | 08:36 PM
DEEZNUTZ's Avatar
has anyone heard of or tried pete z traction bars? will the relocation brackets work with stock lca's? i don't mind spending the money if it really makes a difference.
Old Nov 24, 2009 | 04:23 PM
Z-RATED94's Avatar
I have no experience with the Pete Z system but did try the Lakewood with disappointing results. I would go with the relocation brackets and a good set of LCAs like Fred pointed out. If traction does'nt improve enough, then move on to a adjustable TA. I perfer the chassis mounted type but some complain of the added road noise and the occasional clunk that they are know for.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Aug 5, 2015 08:35 AM
SpeedJunkee
Jul 19, 2015 09:06 PM
