K-Member Advice.
Old Jan 28, 2007 | 12:50 PM
Jlo's Avatar
Jlo
K-Member Advice.
Hey guys, I have a problem, my question is I want to buy a K-member for my LE3/355 build up I want to cut weight but am still iffy about the k-mem. It's for a 95Z, I plan on keeping PS,AC, and getting rid of abs and tcs. The car will see 40% street use and 60% track or 50/50. If I didn't get the K-mem I would be planning on upper and lower a arms with HAL shocks, but I'll probably only loose 8-10lbs on the Arms not really worth it huh, So should I stick with the stock K mem with qa1 shocks for the cars use??
Old Jan 28, 2007 | 12:56 PM
mdacton's Avatar
the qa1 will be the best investment...get those first, the other stuff can wait and do it at once
Old Jan 28, 2007 | 01:03 PM
2000GTP's Avatar
I second the QA1s, you'll see more benefit from running those on all four corners at the track then the k-member.
Old Jan 28, 2007 | 02:21 PM
Jlo's Avatar
Jlo
Thanks guys, that's why I asked ya'll first. What Part #'s would you recomend for the QA1's and what spring rate I'm thinking the 275lbs ones any recomendations??
Old Jan 28, 2007 | 02:38 PM
mdacton's Avatar
if you drive on the street i would go with a 300
i would also go for the 90/10 version. they were not available when i got mine so i had to get them rebuilt and revalved
Be sure to get the rears too....far better than most other drag shocks for the price
Old Jan 28, 2007 | 02:45 PM
Jlo's Avatar
Jlo
will do, which ones for the front they have the "F" series Front Adjustable Shock/ and the "R" Series Drag Race Front Adjustable Shock?? Also what weight reduction have you done on your car?? do you have the stock K mem with stock a arms??
Old Jan 29, 2007 | 09:39 AM
Jlo's Avatar
Jlo
Anybody??
Old Jan 29, 2007 | 12:39 PM
mdacton's Avatar
i have been running the stock a-arms and k-member for 7 years....I ordered all tubular stuff just waiting on it to get here now, the "R" series are the drag racing one 90/10
Old Jan 29, 2007 | 01:42 PM
Jlo's Avatar
Jlo
Okay, I was looking at summit racing, the "R" series are not ride hight adj. and the "F" are. The 300lbs spring will work on both right??
97blackformula
Aug 27, 2015 06:02 PM
jj_burchiel
Mar 5, 2015 07:05 AM
Sniper33
Aug 5, 2003 09:53 AM
Ucantcme57
3rd Gen / L98 Engine Tech
13
Oct 23, 2002 08:39 AM
ShaneS
West South Central
Sep 11, 2002 07:48 AM
