install questions
Old Jan 15, 2006 | 11:24 PM
camarookid's Avatar
install questions
hey guys I am going to swap some parts from a 1999 camaro to 2000 camaro.
Front and rear sway bars-
Rear lower control arms-
****ADJUSTABLE**** panhard rod-
My question is are there any suprises that I should be ready for switching the stock and performance parts from car to car. D
Do I have to re-adjust the panhard bar?
Any tricks or special techniques you guys have would be greatly appriciated!
Thanks, Nick
Old Jan 15, 2006 | 11:52 PM
Re: install questions
It should be a straight-forward swap. You might need to adjust the panhard rod to center the rear end under the car.
Old Jan 16, 2006 | 12:53 AM
camarookid's Avatar
is that something i could do myelf with a little patience or is it more involved than that?
Old Jan 16, 2006 | 05:05 PM
Greed4Speed's Avatar
Patience and a measuring device for the phb, or eyball it.
On the LCA's if they're poly bushed put some grease on the outer egde of the bushings and ithey'll slide up in the bracket easier. If they're rod ended it should go easily enough.
Old Jan 16, 2006 | 05:08 PM
2000GTP's Avatar
Also another tip, when doing the LCAs, only replace one side at a time, don't take off both LCAs at once.
Old Jan 16, 2006 | 07:01 PM
camarookid's Avatar
oh thanks ill be sure to do that.
also another question does it matter if i take off the sway bars with the tires under load, or if they are hanging in the air, because i heard somewhere that they should be under load for an easier install......... urban myth, or truth?
Old Jan 17, 2006 | 07:59 PM
2000GTP's Avatar
When I did the rear sway bar, I put the car up on jackstands. It made for a very easy install.
Old Jan 17, 2006 | 10:31 PM
Bud M's Avatar
When I do swaybars I do them on ramps
Bud M's Avatar
Bud M's Avatar
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
Brent94Z
Mar 21, 2002 04:44 PM
