How to install rotors
Old Sep 19, 2005 | 12:12 AM
robertotrevino's Avatar
Ok, so I bought some new rotors from ebay,... I had never pulled apart the caliper from the rotor to look at it so, my mechanical skills are pretty much crappy.. anyway, I took it off and took of the rotor, I put the new rotor in just to find out it is a tad wider than the stock ones, same fit, same diameter, just a tad wider, what do I do to fit them? The caliper wont fit cuz the pads are just to close together/.. thnx.
Old Sep 19, 2005 | 01:14 AM
Z95m6's Avatar
Re: How to install rotors
You usually need to compress the piston in the caliper back in. It can be done with a C clamp or i believe they sell special tools to do it also.
Old Sep 19, 2005 | 10:35 AM
but wont it be pressing against the rotor once I take the c-clamp off? how do I adjust the separation lenght?
Old Sep 19, 2005 | 10:38 AM
stingercamaro's Avatar
After reassembling, you pump the brake until the pedal firms up. That firm feeling is the pad touching the rotor.
Old Sep 19, 2005 | 08:47 PM
chrisn's Avatar
make sure you tourque EVERYTHING down when your done. and dont forget to use brake cleaner on the new rotors.
Old Sep 19, 2005 | 09:38 PM
Done, thnx! they work great
Old Sep 20, 2005 | 02:57 PM
O-taka's Avatar
2nd that on torque. use some loc-tite on the 2 caliper bolts. one of mine came off once and that was not fun. good thing i was going slow. big rattling as the caliper was hitting the inside of the wheel
Nov 18, 2023 07:21 PM
carguy0119
Apr 11, 2016 11:11 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
hotrodyou1
Dec 20, 2014 10:05 PM
GigaMp3z
Feb 20, 2003 02:57 PM
