How to adjust e- brake
Old Mar 1, 2005 | 04:50 AM
Godly96_SS_Here's Avatar
i just bought a 96 ss camaro and my e brake is making noise i was wondering the best way to adjust it? It has a slight clunking noise when driving at low speeds. any help would be great
Old Mar 1, 2005 | 07:35 AM
Re: How to adjust e- brake
The e-brake clunks? How can that be? Need more detail on that.
The e-brake is normally self-adjusting.
Old Mar 1, 2005 | 03:56 PM
when i get under the car and shake the e-brake line you can hear the same noise as when im driving and hear the clunking
Old Mar 1, 2005 | 08:54 PM
pHEnomIC's Avatar
Shoebox is correct, its designed to take up slack over time so the ebrake stays tight and you dont have to adjust it. Id make sure everything is mounted correctly and all the bolts are tight down there.
Old Mar 1, 2005 | 10:01 PM
3gc's Avatar
3gc
Check the mount where the e-brake cable splits, it's above the driveshaft i beleive.
Old Mar 2, 2005 | 12:00 AM
Killaz's Avatar
aight thanks
Old Mar 2, 2005 | 03:08 PM
Im not finding anything except when i pull the brake one click and it stops making the noise
Old Mar 2, 2005 | 09:48 PM
ttt
Old Mar 3, 2005 | 04:34 AM
Killaz's Avatar
well i say you should buy a LS1 then everything would be ok.......
J/K good luck finding out
Old Mar 3, 2005 | 04:39 AM
thx ill try that but i might buy a vette
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
R@mpage
Apr 20, 2015 10:02 AM
jb4xx
Feb 2, 2015 10:00 PM
