Post LS1 brake upgrade - steering light and car veers off to the left.. bent knuckle?
Old Mar 2, 2005 | 08:04 PM
pillagenburn's Avatar
Just got through putting on new steering knuckles, calipers and bleeding the whole system. Problem is, the car veers off to the left and the steering is kind of soft. I haven't gotten an alignment yet so that might be it, but are these symptoms of bent steering knuckles? i need help on this bad guys
thanks!
Old Mar 2, 2005 | 08:23 PM
stereomandan's Avatar
Re: Post LS1 brake upgrade - steering light and car veers off to the left.. bent knuckle?
You need to take it to an alignment shop and see if they can align it. Most likely, you just need to get things straightened out. Hopefully. Make sure you let them know what you did, so they know that things might be pretty far off to start.
Dan
Old Mar 2, 2005 | 09:20 PM
Black_Z28's Avatar
Dan
Yep, get that thing to an alignment shop. I was pretty lucky. I lowered my car the same time I did the LS1 brake upgrade and I didn't really even need to get it aligned, but I did anyways. Better to be safe than sorry.
Old Mar 3, 2005 | 12:17 AM
Z95m6's Avatar
i think you need to get it aligned first. Its just a guessing game why it could be pulling until you get the alignment checked out. My car didn't need to be aligned when i had it checked out after i did my LS1 swap.
Old Mar 3, 2005 | 12:44 AM
OBE1 95Z28's Avatar
You stated that you installed "new" steering knuckles...why would you suspect a bent steering knuckle? Get it aligned first.
Old Mar 3, 2005 | 04:23 PM
Z95m6's Avatar
I maybe wrong but i think he meant New as in a set of used, New to his car LS1 knuckles.
Old Mar 3, 2005 | 05:51 PM
NJSPEEDER24
Guest
Posts: n/a
When replacing suspension components you will usually need to get the car aligned. Before they align it they check for worn steering/suspension parts anyways.
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
mjcent922
Jul 27, 2002 12:42 PM
