home made subframe connectors
Old May 12, 2004 | 10:06 PM
92RSChevy's Avatar
subframe connectors problems
Ok I got my car back from the shop today and noticed they used angle iron for the subframe connectors. Now, the car is going to have a 355 TPI with a possible blower or NOS. The rearend gear I plan to run are 3.73 and I plan to launch in hard when its at the track. The angle iron appears to be 1/4" thick and looks like plan steel. The car is going back to him this weekend to have the angle iron welded better to the car. I need some feedback on if these angle iron pieces will work or what I should do before I go back there to get it completely welded.
Thank You for the time
Old May 13, 2004 | 10:37 AM
Bone Daddy's Avatar
I don't know if I would trust that shop, there angle iron, or there welding skills.
I/others only trust sfc's with tubular steel, or squared steel tubing.
Old May 14, 2004 | 03:15 PM
Xride's Avatar
angle iron??? go back and kick the guy that did that in the nuts.
get them to use tubular or boxed steel.
"plain steel" is fine.
Old May 14, 2004 | 09:03 PM
Bud M's Avatar
I wouldn't like angle iron either
But then I would just buy a set.
Old May 15, 2004 | 10:22 PM
92RSChevy's Avatar
thanks for the time first off.
Yea I am really mad at this guy. He doesnt return my phone calls or anything and I got him to fix it this weekend and now has some "flooding". well I think I am going to buy a kit and I hope I can cut this angle iron junk off and try to find a welder that can do it for me .
Old May 15, 2004 | 11:13 PM
92RSChevy's Avatar
I have another question now. When I take these pieces of angle iron out ( there tacked lol so it should be too hard) and go to install the real squared subframe connectors will the frame of the car be tweaked or anything from welding heat or what not? I maybe put like 30 miles on the car sense the angle iron was installed and I dont make enough power to tweak anything yet.
HOFFICER
Apr 6, 2020 10:36 AM
RUENUF
Mar 13, 2016 03:39 PM
R@mpage
Apr 20, 2015 10:02 AM
QuickSilver02
Apr 7, 2015 11:12 AM
