HELP me pick a shocks,struts and spring for 01 Z28
Old Sep 28, 2007 | 05:36 PM
corbraeater's Avatar
So I am posting this for my dad he has 01 Z28 w/ about 105k…he looking to replace the shocks and struts on the car and the springs too. He would like to find a spring that will lower the and 1”. So please he me out here, i dont know much about suspension.. THANKS
i found this at thunder racing but i dont know how good it is and if i need anything else...
part #133-BTS-7501
Bilstein Suspension Kit, 1993-02 F-Body
Includes 4 Matched Shocks and Springs. Lowers vehicle approximately 1 inch.
Old Sep 28, 2007 | 10:07 PM
Greed4Speed's Avatar
The Bilstein kit isn't that great. Look into Hotchkis or BMR springs.
Old Sep 28, 2007 | 10:08 PM
SS1156's Avatar
There is one man for the job: Sam Strano. His springs and sway bars are matched with Koni's or Bilsteins. The stuff is real nice. That's the next group of stuff going on my car.
Old Sep 29, 2007 | 11:39 AM
Bud M's Avatar
Yeah, talk to sam. stranoparts.com
Old Sep 29, 2007 | 11:55 AM
Bayer-Z28's Avatar
^ Yep.. Strano Springs and Koni Singles.. THe fronts may look like struts, but they're like a coil over.
Check one of the latest issue of GMHTP w/ the Strano Springs and Koni Single adjustable shocks. Good setup.
Old Sep 29, 2007 | 06:30 PM
No matter how good they are, Strano springs lower more than an inch.
Old Sep 30, 2007 | 05:02 PM
yeah i got that issue last week...so i gonna look into some koni shocks.. i didnt think he wants to more than 1" so who should i look at for the springs..
Old Oct 1, 2007 | 06:28 PM
Sam Strano's Avatar
As do pretty much all springs. I'm one of the "not low" springs, and FWIW, we're pretty much between 1-1.2" on most cars. I don't think that .2" or so is really that noticeable. And I find that most folks kick out a number that's largely arbitrary, and often based on pictures of cars that have springs that are "supposedly" x.xx" drop.
Old Oct 1, 2007 | 06:49 PM
danhr's Avatar
try swapping to v6 struts up front and v6 springs/shocks in the back.
I did that to my car and it lowered it about 3/4-1"
it drastically reduced body roll and greatly increased weight transfer. So I hook better off the line, and my car handles better. and for all four corners, I paid $40 for everything off of a 10K mile car.
I had bilstein HD's on my car before and the difference is night and day.
Old Oct 1, 2007 | 08:43 PM
How would softer V6 springs reduce body roll?
Old Oct 1, 2007 | 08:45 PM
danhr's Avatar
Only thing I can think of is the lower center of gravity from being dropped that 3/4"-1"
I can say that there's a lot less body roll in my car and in my buddy's 95 z28 that got the v6 swap.
Old Oct 1, 2007 | 10:45 PM
Moshbmx1's Avatar
Koni singles matched with strano springs FTW
Old Oct 2, 2007 | 10:23 AM
If he goes Koni then he can use the stock springs and use the lower perch on the front for a ~.75" drop and do the !isolator mod on the rear springs.
Old Oct 2, 2007 | 02:31 PM
Sam Strano's Avatar
The V-6 springs are softer than V-8 springs. If your cars handles better it's because your Bilstein's were done and the DeCarbon's you put on are better. The car is lower because the springs are softer. But springs and bars control roll, softer springs do not make for less body roll.
Something is fishy here, and since you didn't just change the springs, but both the springs and shocks this isn't a valid argument. Softer springs will not decrease body roll. But shocks can and will slow the rate of it if they are better than what you had, and that is interpreted as just "less roll" all the time.
CamaroHeed
Mar 18, 2020 09:50 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
slothgrant
Aug 22, 2002 03:01 PM
