Help the car not wheelie as much without bars help inside
Old Oct 25, 2007 | 10:21 AM
sleeperz28's Avatar
I have qa1 double adjustable shocks in the car right now. I havent tried it yet but will stiffening the shocks all the way help keep the front end from coming up as much. Im trying to get the 60's in the 1.2'.
Also i hear people straping the front end down. To do this do i just weld a tab near the shock tower and get some ratchet straps?
If anyone has tried both please let me know your thoughts
thanks
Old Oct 25, 2007 | 12:14 PM
Front suspension limiters changed this:
....into this:
Don't make your own.... there are kits avaiable, using aircraft grade cable.
Old Oct 25, 2007 | 12:26 PM
danhr's Avatar
worst........mod.............ever
buddy of mine did it to his 3rd gen.... he went from putting the car on it's back bumper to getting them < 1 ft in the air.
Old Oct 25, 2007 | 01:56 PM
sleeperz28's Avatar
....into this:
cool. my car looks like the first pic. Fred you see my 8 second pass? If i keep the front down this weekend and can lanch hard and get into the 1.2's i think ill be on my way for low to mid 8's. I just picked up a comp eng kit im going to put it on now
Old Oct 25, 2007 | 01:59 PM
windsma's Avatar
The hillbilly's around here weld chains up, to limit travel.
Old Oct 26, 2007 | 07:41 PM
RE AND CHERYL's Avatar
The linmiters will ehlp the launch but you will have to play with them a bit to find just the right length.
Have fun
Re'
Old Oct 27, 2007 | 12:26 PM
That's why there are multiple holes in the lower bracket.
Old Oct 28, 2007 | 12:16 PM
sleeperz28's Avatar
I installed these and went to the track yesterday. On the lowest setting i couldnt get the car to hook at all. I pulled them off and put the shocks as stiff as they could go. this kept the car on the ground and got me a 1.35 60'. I didnt have anymore time to play with them but maybe if i hit the tire really hard it might work. But from what people on the side lines said the car would come up and the secound the limiters hit the car would look like it nose dived.
I did manage a new best of 8.81@154. Same boost as last time. After i get a 5 bar map i should be able to go for low 8's high 7's
Old Oct 30, 2007 | 10:18 PM
sn8ke eatr's Avatar
that first pic is so much cooler. ill take the slower et to say my car can do this.
Old Oct 31, 2007 | 05:13 PM
Unfortunately, it takes a big set of 'nads to keep one's foot planted on the throttle, when the rear bumper is on the track and all you can see is the sky. In the first photo, the car was already on its way down. Destruction of the oil pan occured a second or so after the photo was taken.
This was a very early video... only the second pass the car made with a new engine. The first pass was made with wheelie bars, and they sucked.
http://www.injuneer.com/images/Video...eBax%20876.WMV
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
slothgrant
Aug 22, 2002 03:01 PM
