Front strut help
Old Dec 16, 2007 | 09:25 AM
Camedmaro's Avatar
Front strut help
Well, I was in the process of installing the front lowering springs. Everything thing comes out no problem. I pull the strut out and see that the top nut to pull the strut out is rusted to hell. So we take the impact to them to hopefully break them loose. One of them almost came off but stops. Any idea of how to get these off without cutting the strut? I was thinking of cutting the bolt but, I don't have a small enough cutting tool.
Old Dec 16, 2007 | 01:22 PM
Greed4Speed's Avatar
If you're going with lowering springs you shouldn't run stock shocks anyway.
This is a common problem. I ended up taking a chisel to the nut. When going back together, pack that area with grease.
Old Dec 16, 2007 | 03:43 PM
You are going to want to replace the shocks anyway. No sense in doing all that work and leaving an old shock on there. Just chisel/Dremel off the nut or cut the rod. Make sure you have the spring compressed or you will die. BTW, it's a coil-over shock, not a strut.
Old Dec 16, 2007 | 06:27 PM
TobyZ28's Avatar
FYI although it sounds harsh he's not joking at all...
Old Dec 20, 2007 | 03:50 PM
Camedmaro's Avatar
I got the lowering springs on. The only problem is the front is slammed and the back didn't lower much at all. Would it be because I have LCA's on the back?
Old Dec 20, 2007 | 04:55 PM
If you mean did the back drop less than the front, because you have AFTERMARKET LCA's in the rear, the answer is no. The LCA's have nothing to do with the ride height.
Old Dec 20, 2007 | 05:01 PM
Camedmaro's Avatar
Ok, thanks.
HarleyZ28
Oct 5, 2015 06:23 AM
KYWes
Apr 3, 2015 07:59 PM
Magenta_Hearts
Mar 22, 2015 02:44 PM
Jibberish18
Aug 28, 2002 12:46 PM
