Front control arms Q
Old Jul 3, 2004 | 11:00 PM
nathanpritchard's Avatar
Since I have my motor out anyway I decided to go with the BMR tubular K-member. Right now I'm trying to decide if I want the upper and lower BMR tubular control arms. I remember someone mentioning to me that I might need the adjustable tubular control arms if I'm lowering the car. I'm dropping it with an Eibach Sportline kit, which is a pretty good drop. Will I need the adjustable upper and lower control arms to correct the suspension geometry?
Thanks,
-Nate
Old Jul 3, 2004 | 11:38 PM
Spinner's Avatar
Back to factory specs, yes. There isnt enough camber adjustment in the stock uppers to bring you back to specs.
Old Jul 6, 2004 | 11:11 AM
To set it back to factory specs, I'll need the adjustable ones. Am I going to cause any problems with the feel of the suspension if I go with the non-adjustable?
I wouldn't know how to properly set the adjustable's up anyway. Is this something any decent chassis and suspension place should be able to setup?
-Nate
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
R@mpage
Apr 20, 2015 10:02 AM
thenewkid
Apr 12, 2015 07:42 PM
dbrockma
Feb 16, 2015 02:56 PM
