Front control arms Q
Since I have my motor out anyway I decided to go with the BMR tubular K-member. Right now I'm trying to decide if I want the upper and lower BMR tubular control arms. I remember someone mentioning to me that I might need the adjustable tubular control arms if I'm lowering the car. I'm dropping it with an Eibach Sportline kit, which is a pretty good drop. Will I need the adjustable upper and lower control arms to correct the suspension geometry?
Thanks,
-Nate
Thanks,
-Nate
To set it back to factory specs, I'll need the adjustable ones. Am I going to cause any problems with the feel of the suspension if I go with the non-adjustable?
I wouldn't know how to properly set the adjustable's up anyway. Is this something any decent chassis and suspension place should be able to setup?
-Nate
-Nate
