f-body rear bump stops
Old Feb 20, 2011 | 11:22 AM
1badasZ's Avatar
I could be wrong but doesn't somebody make some billet/pollyurethane rear bump stops for the f body that's already clearanced for larger n wider wheels?
Old Feb 20, 2011 | 12:52 PM
Re: f-body rear bump stops
The problem with wide wheels/tires is due to BOTH the bump stop metal and the body sheet metal that it bolts to. You have to grind away both, not just the bump stops themselves.
Old Feb 20, 2011 | 12:56 PM
1badasZ's Avatar
Oh ok thanks. I still have salad shooters for now but my bump stops are GONE so I was gonna replace them with those for future reference
Old Feb 20, 2011 | 01:44 PM
bluz28's Avatar
Just get a set of ES #9.9137, about $20. All you need to do to mount them is either cut off the lip the fits into the factory bumpstop grove, or slightly trim down the ES bumpstops to fit around the lip.
You should be able to get them at a local auto part store, that carries ES products.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
ModdedNerd
Dec 25, 2014 05:51 PM
