Eibach spring height vs. stock spring height
Well I finally got my Eibach Pro Kit springs in today. I took off my stock rear spring, and it's the same height as the Eibach's. I can tell the Eibach's are softer though. I bought them used, so did I just get burned (and he sent me some beat stock springs), or is this normal? I always thought the lowering springs would be shorter. Thanks
Re: Eibach spring height vs. stock spring height
You sure he didn't send you sportlines? They are softer than stock (and not a good performance spring... they're for the lowrider look).
The Pro-Kits have a progressive spring rate. The top coils are going to feel softer, and compress more under the weight, giving you a lower ride height. The springs should be a dark gray powdercoat, and have the Eibach part #'s on them.
Thanks for all teh help!
Dec 1, 2014 08:08 AM
