E-brake light wont go away
Pretty self explanatory,but my e-brake light wont turn off on the dash. When e-brake is disengaged, the light stays on. Any ideas how to make it go away?
and you have made sure you put the ebrake all the way down and wiggled it into place?? sometimes i have to push the button in and go all the way up and all the way down to get the light to go off in my wifes car 01 rs.
Wrong forum, since its not an "engine" question... but I'll answer the question before I move it to the correct forum.
The "BRAKE" light serves 2 different purposes. Obviously its for the E-brake. But it also comes on if you have unequal pressure in the front and rear braking systems. Could mean you have a leak in either the front or rear, air in the system, etc. The light is activated by the pressure switch in the block attached to the right side of the ABS motor pack.
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
