Lower on rear driver side
Old Jul 15, 2009 | 09:55 PM
always faster's Avatar
Well my front end seems ok but in the back the driver side is like 1" lower than the pass side.Even without measuring it i could clearly see it.
So what could cause this?
I took my rear springs(strano springs) and isolator off but they where fine so i ve install them back.Also tried to switch them and no result.Springs are installed the same way.
Stranos springs on Koni SA
umi rear lca(poly/rod end)
umi adj panhard rod
strange 12 bolts
Old Jul 16, 2009 | 08:13 AM
JohnD's Avatar
Try swapping the springs and see if the problem moves too.
Old Jul 16, 2009 | 02:51 PM
bluz28's Avatar
Are the ends of the pigtails on both springs pointing toward the front of the car?
Disconnect the rear sway-bar endlinks, is it level now?
Old Jul 17, 2009 | 12:57 PM
Like stated already tryed it and same result
[QUOTE=bluz28;6040534]Are the ends of the pigtails on both springs pointing toward the front of the car?
Disconnect the rear sway-bar endlinks, is it level now?[/QUOTE
At first not the coils where pointing backward,i ve reinstall them pointing forward and same problem.
May i ask why the guess on the endlinks???
Old Jul 17, 2009 | 02:15 PM
bluz28's Avatar
If you disconnect the endlinks and the problem goes away then you know it's either a swaybar(bent), or endlink (damaged,mismatched,improperly adjusted) problem.
Old Jul 18, 2009 | 03:30 PM
Ok i ll check that this week and give some further news.
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
Bando
Oct 7, 2002 07:36 PM
