Do you think this is the problem????
Old Jun 15, 2006 | 11:08 PM
Mike96z's Avatar
I have a 96 z28 LT1 and my steering wheel seems to be really loose, like I can go 2" in both left/right directions before the wheels will turn, like there's alot of slack. Do you think it's the steering knuckle? Joint? that couldve went out from being so worn and it has alot of play in it? Thanks for info, also are there any aftermarket things, my steering isn't tight at all.
Old Jun 15, 2006 | 11:20 PM
MyShibbyZ28's Avatar
Re: Do you think this is the problem????
Most likely the rack and pinion wore out. Mine is like that too. If you end up replacing the rack and pinion I can help you with how to do it.
Other than that, look in the engine bay. You can see the knuckles, and steering joints on the drivers side there.
Old Jun 15, 2006 | 11:32 PM
Mike96z's Avatar
Yea I just put a new engine in but wondered if it was the rack and pinion or the steering knuckle. Knuckle looks pretty old though. How much will a new rack and pinion usually run?
Old Jun 16, 2006 | 02:32 AM
1racerdude's Avatar
Look at the steering while someone wiggles the slack in the wheel back and forth. Then ya can tell if it's tie rod ends(joint with slack at the wheels) or the rack if ya don't see anything moving in a strange way it's the rack.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
