Creaking noise from rear brakes???
My '96 LT1 Camaro's rear brakes are making a creaking noise when at a stop depressing the brake pedal. It sounds like old, creaky, wooden steps. I can also feel a little feedback (light roughness) through the brake pedal when the noise is happening. It is very annoying when at the drive thru or a stoplight and my creaks.
If I pull up on the e-brake a couple times then depress the brakes the noise disappears until I start moving and have to use the brake pedal again to stop. I also have to pull my e-brake all the way up a couple times too for it to engage somewhat decent.... don't know if that would be related or not. If you guys could give me a couple ideas of things to look at and check would be awesome! TIA!
Jeff
If I pull up on the e-brake a couple times then depress the brakes the noise disappears until I start moving and have to use the brake pedal again to stop. I also have to pull my e-brake all the way up a couple times too for it to engage somewhat decent.... don't know if that would be related or not. If you guys could give me a couple ideas of things to look at and check would be awesome! TIA!Jeff
squarehead
Nov 21, 2014 08:02 PM
trefidy
Jul 26, 2002 03:40 PM
