Car swaying at 130+
Old 04-19-2006, 07:20 PM
69gto96z's Avatar
Car swaying at 130+
I had my car up around 130 to 140 the other day and it the car felt like it was swaying real bad. I was wondering what suspension mods I could do to help stop this. The only suspension mod I have so far is boxed LCA's.
69gto96z is offline
Old 04-19-2006, 08:40 PM
teke184's Avatar
Re: Car swaying at 130+
just about any suspension is gonna feel like it's ready to lift at that speed.
but the obvious things are springs and shocks.
teke184 is offline
Old 04-19-2006, 09:25 PM
Greed4Speed's Avatar
SWAYbars, fresh bushings, good tires and good shocks.
Please tell me you're smarter than to do that speed with the stock pads, rotors, and brake fluid thats been in the car since it was new...
Greed4Speed is offline
Old 04-19-2006, 09:39 PM
Daniel6718's Avatar
STOP GOING THAT FAST!!! its dangerous...trust me...
Daniel6718 is offline
Old 04-19-2006, 11:56 PM
69gto96z's Avatar
Got brand new tires on it. I just did a recent brake job and bled all 4 calipers. I made sure I had an open bridge when I got on it, I just wanna help stabilize it some.
69gto96z is offline
Old 04-20-2006, 12:31 AM
firebird84's Avatar
And anway who said anything about stopping all you have to do is make sure to drive around people and youll be fine.
firebird84 is offline
Old 04-20-2006, 01:07 AM
Daniel6718's Avatar
idk mine seems pretty stabile at 140 plus(without front swaybar!
but damn i dont lkike it much above 125..i gets a lil nervous even thinkin about it...ive done 150+ in it...it was fun, till i get done and thought about it....
o yeah and ive done 130 numerous times with d/r at 14 psi...try lowering that beast, and more tire pressure
Old 04-20-2006, 11:39 AM
Not all tires or brake components are ceated equal....
Old 04-20-2006, 10:08 PM
zyoulater's Avatar
I use to hit 160+ in my Z all the time, when safe of course. I'd had a few suspenison parts though. The car felt stable as hell. One of the best cars at high speeds i've ever been. My car never swayed or felt like it was floating at all. I'd say the very least is to make sure you have good tires, good shocks, and good stiff springs. This was my suspenison set up on my 01 Z28, I hope this helps.
BMR STB, ADDCO 35mm front swaybar, 21 MM rear swaybar, eibach pro kit springs, koni adjustable front shocks, bilstine HD rear shocks, adj panhard rod, adj tq arm, DD SFC's, BMR LCA's, and Reloaction brackets.
Tony
zyoulater is offline
Old 04-21-2006, 01:54 AM
69gto96z's Avatar
Thanks for the info. I was thinkin about some springs/shocks as my first thing to try.
69gto96z is offline
Old 04-21-2006, 03:07 PM
OBE1 95Z28's Avatar
Swaying or wandering....front alignments can be optimized for stright line stability at speed or cornering.
OBE1 95Z28 is offline
Old 04-23-2006, 02:53 AM
69gto96z's Avatar
I had the front end aligned about 8k miles ago, but it was on old tires. Maybe I should have it done again.
69gto96z is offline
siguy
11-27-2014 10:07 AM
thenewkid
11-27-2014 09:41 AM
USAirman93
11-24-2014 03:37 PM
IgorT.455/406
02-01-2005 06:18 AM
Z28STYLE23
08-17-2002 07:40 PM
Quick Reply: Car swaying at 130+
