C5 front brake conversion 95 Z drag skinnys
Old Sep 17, 2006 | 03:26 PM
streetbad's Avatar
What would be best?
Old Sep 17, 2006 | 08:13 PM
NOSCaMaRo's Avatar
Re: C5 front brake conversion 95 Z drag skinnys
Originally Posted by streetbad
What would be best?
Not sure what you are asking? If you want to run the C5 brakes you need at least a 17" wheel so skinnies in the front arent going to clear them.
Old Sep 22, 2006 | 04:59 PM
Severous01's Avatar
i think you should just go with some z06 wheels, total shipping weight for mine was just over 20 lbs for all 4. 17*9 clears the calipers and tires are prety cheap at 100 a piece for some ZRi's.
Old Sep 23, 2006 | 06:24 PM
streetbad's Avatar
5lbs each??? Better double check.
Old Sep 24, 2006 | 12:47 PM
Severous01's Avatar
i had 4 boxes...shipping weight for the whole deal was 20 lbs. no rubber, just wheels.
Old Sep 26, 2006 | 07:58 PM
nfa's Avatar
nfa
Are you sure????
My SS wheels (17x9) where about 22 lbs EACH. Im not sure if there is a wheel out there in that size that weighs 5 lbs each.
Old Sep 27, 2006 | 10:01 PM
Severous01's Avatar
??? doesnt matter really...all i know is they are really light. i had some boyd's that were heavy as a mug...and some factory salad shooters that were heavy in comparrison.
something to think about is the magnesium C5 wheels. i know Mg is lighter than Al any day. and they're cheap.
Old Sep 28, 2006 | 03:40 PM
sc1twntrbo's Avatar
if ya got the cash ccw makes a 17inch skinny
Old Sep 28, 2006 | 04:19 PM
You can't be serious.... 5# per wheel, shipped? The Bogart "drag use only" 15x9.5's are the lightest wheels made and they are close 10# apiece. Check the list of wheel weights in the FAQ in the "wheels and tires" forum.
Old Sep 28, 2006 | 11:09 PM
black97z28LT1's Avatar
I think what you are trying to get at is the lightest possible wheel infront and correct me if i am mistaken but also the wheel that will create the lest amount to contact resistance to the road?
Then i would not go w/ the 17x9 zo6's even if they are five pounds each , lol
I know weld makes a 16inch wheel might want to check into that or something
Magenta_Hearts
Mar 29, 2017 08:54 PM
Brake_L8
Jan 20, 2015 09:44 AM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
slocody
Feb 10, 2003 01:04 PM
