Are C4 and C5 brake adapters the same?
Back when I did my brakes, over 10 years ago, I used 13" C4 brakes and an adapter to make it work. Basically a Baer setup without the expense.
Having been out of the LT1 scene for so long and now seeing that C5 conversions are the big thing. Are the adapters the same? The braking is still much better than stock but always could be better
robsWS6:
I installed this setup: http://www.umiperformance.com/produc...item_id=212022 They are 13" rotors. The link will provide a reasonable look at the parts, including the brackets, calipers and rotors. I assume the only difference might be in the calipers.
whitehooptie
Jul 12, 2015 06:10 PM
