Bump steer and rag joint question
Old Oct 20, 2004 | 05:51 PM
1 Hot Z's Avatar
Anyone using baer's bump steer for lowered cars. and aslo this aluminum rag joint from unbalenced engineering?http://www.unbalancedengineering.com/Camaro/
Any noticeable improvement in steering from the bump steer kit. I have also heard these kits wear out faster than the original equipment. Anyone have any problems?
The rag joint- is there any vibrations or any other problems going to this solid piece rather than the rubber?
Thanks in advance, Scott
Old Oct 21, 2004 | 06:49 AM
bmillington's Avatar
Re: Bump steer and rag joint question
The steering shaft and the gear box would need to be perfectly inline with each other or it wouldn't feel smooth full circle.
Old Oct 26, 2004 | 11:44 PM
Z28barnett's Avatar
I have a rag joint eliminator and I am happy with it.
At highway speed no bothersome vibration comes through it.
I notice a little more up and down vibration in the wheel on hard bumps.
Not sure if that is the joint or not, I made a lot of other changes.
The shaft has 4 U-joints, no need for perfect alignment. The steering feels great.
If you have headers it makes more sense, the pipe run very close to where the rubber is.
blac94Z
15
Mar 2, 2015 12:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
