Broken Swaybar endlink
Old Apr 15, 2005 | 11:03 AM
MRBoss429x's Avatar
I narrowed down some rear clunking to a broken swaybar endlink. On the left side all I have is the topbusing and a metal spike on the bracket the swaybar bolts to. Anyone know where I can get this part/how much? Also do new swaybars come witht eh bolts and bushings? If so where can I get a cheap one? Thanks a lot.
Old Apr 15, 2005 | 01:05 PM
sir dyno's Avatar
Re: Broken Swaybar endlink
New swaybars will come with new endlinks check out the sponsers, check in the suspesion section in the sponsers website, im sure you will find what you're looking for.
Old Apr 15, 2005 | 05:45 PM
MRBoss429x's Avatar
Do bushing kits like the ones here http://www.ls1speed.com/catagory.cfm...%20/%20Chassis (near bottom) contain bushings only, or the metal nut/bolt too?
Old Apr 15, 2005 | 05:53 PM
sir dyno's Avatar
link does not show end link bushing kit.
Old Apr 15, 2005 | 06:10 PM
MRBoss429x's Avatar
So "Rear Sway bar polyurethane bushings with link kits" isnt it? Where can I get the whole endling, bolts and bushings?
Old Apr 15, 2005 | 10:14 PM
OBE1 95Z28's Avatar
Many auto parts stores carry the end links and poly bushings. Pep Boys has them. Measure the length of the bolt as they come in various lengths.
Old Apr 16, 2005 | 01:39 PM
sir dyno's Avatar
Iam sure if you buy the whole kit, the bolts and bushings come with the kit. Or if you just buy the end links the bolts and bushings are included. To be sure just email a sponser, Im sure you will get a quick reply. Good luck.
Old Apr 16, 2005 | 08:57 PM
MRBoss429x's Avatar
Went to autozone and found em right on the shelf, 20 bucks. Thanks guys!
football4life
Oct 4, 2015 07:48 AM
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
maverickmk
Sep 1, 2015 09:17 PM
realistyc
Jul 28, 2015 07:32 PM
