Brake Rotors? which ones?
my stock ones feel kinda wraped to me plus this gives me a reason to upgrade them, should i get cross drilled or slotted or the combo of slotted cross drilled? i heard slotted are the best but i want to know for sure. oh yea where is a good place to find 4 of these rotors at a good cost. thanks guys
do you road race? if not its not worth it..
Just replace them with autozone rotors.. they are better and last longer than stock.
slotted rotors eat up pads
drilled rotors, often, if cheap, will crack.
if you spend $ and get good ones but never really use them its a waste.
If you have a lt1 get the ls1 brakes they are around 300 and will be a lot better. If you have an ls1 car and 17's get the c5 front brakes. Those are better. If you just want to throw some hawk pads and brakes lines with good fluid, again better than stock. But if you got some money there is Baer,Bremo,etc. that have 12-14 inch rotors, a whole new assembly, everything.
>Has anyone dealt with the rotors from Power Slot called "Pro Stop" http://www.powerslot.com/prostop.html ?
i got my powerslot brakes really cheap from autozone i thionk they were 30 or 60 bucks, anyways get some hawk pads and goot brake fluid and that should hold you for a while, the only time they fade is when i slow down fast from 130-140 but i dont do that much so its ok
Originally posted by bad95formula
true
true
