brake rotors ( need Advise)
Old Feb 23, 2010 | 08:11 PM
football4life's Avatar
Hey I have a guy and he needs me to change his brakes. its a 98 camaro ls1, Im wondering what is a good rule of thumb for changing rotors too. He has some grooves in the rotor that can be felt when running your finger over, but I have seen worse.
So should I change the rotors?
Thanks,
Josh
Old Feb 23, 2010 | 10:35 PM
dbrunner2's Avatar
If you can feel them with your finger as distinct grooves (not just a slightly rough surface), I would definitely change the rotors. Otherwise, the pads have to wear down to match the grooves, and until that happens you've got much less pad contact area than you should, meaning poor brake performance.
Old Feb 24, 2010 | 08:28 AM
Thanks, that was what I was thinking I was just making sure before he spent the money.
Old Feb 24, 2010 | 09:33 AM
LearJet's Avatar
Alternatively you could just have the rotors you have turned. Much cheaper. If your going to replace them with something better than stock then go for it.
Old Feb 24, 2010 | 11:47 AM
Bud M's Avatar
Yeah, get them turned at your local brake shop. Why replace if its not necessary?
Old Feb 24, 2010 | 05:26 PM
koolaid_kid's Avatar
As a counterpoint, why risk it for a performance car? Quality rotors are not tha expensive these days.
Personally, I replace rotors and pads at the same time. Even on my DD. Not worth the chance for me. But that's just me.
Old Feb 24, 2010 | 06:04 PM
LearJet's Avatar
Sure if your going to get cross drill and slotted rotors I say do it. Otherwise if the rotors are just slightly grooved stockers your can get em turned new again at pepboys for less than the cost of one new one. They won't turn them if they are too thin. A freshly turned stocker will work better than a new stocker due to the finish it produces. But by all means, replace them with a QUALITY rotor, not a stock one if you go that route.
Old Feb 25, 2010 | 10:02 AM
Bud M's Avatar
Risk what? Turning rotors is a standard brake maintenance procedure. Nothing risky about it.
Old Feb 25, 2010 | 10:37 AM
Chance????
A set of correctly turned rotors are going to be a lot more reliable than the Chinese crap that seems to be the only thing available on the market these days.
Boss002
Jan 20, 2016 12:17 PM
whitehooptie
Jul 12, 2015 06:10 PM
gonzo275rltw
Jul 11, 2015 04:19 AM
