4th Gen Sagging Doors.
Old Feb 7, 2010 | 08:35 PM
95mysticta's Avatar
Having an issue with my doors on my 94 formula with 215k. Door is rubbing the front fender a bit and i have to adjust the window track so it doesnt leak. Do our doors have pins or hinges that wear after long periods of time? What can i do to fix this problem?
-Matt
Old Feb 8, 2010 | 11:42 AM
n2ceptor's Avatar
You have to replace the whole hinge assy.... Over time, because the doors are so heavy, the hinge does were down...
Old Feb 14, 2010 | 08:05 AM
Fish-man's Avatar
good luck finding hinges... GM no longer stocks.
I r&r'd my Formula with a set of pins from total auto... you have to remove the hinges, grind/press out the old pins. the new ones bolt in, and have knurls to hold the hinge--- unfortunately 1 of the 4 knurls doesn't engage on my one pin hole... not sure if this will cause long term probs or not.
It was about a 2.5 hour job after adjusting the door at the end.
Old Feb 16, 2010 | 01:42 PM
95mysticta's Avatar
Thats not the answer i wanted to hear unfortunatly. Its not that bad but you that you knows its not working properly. Ive adusted my windows so that they dont leak much but just a pain in the ars and looking to find a solution. Would finding hinges off another car help or be a waste of time?
Old Feb 26, 2010 | 09:22 AM
95mysticta's Avatar
Well im picking up a set of good shape door hinges of a low km parts car in hope i can swap hinges and line up the door and be done with it. I really dont it to get any worse and start having leaks around the windows cause it wont sit flush against the weather stripping
G-BODYT56
Jan 14, 2022 11:14 PM
Aaront810
Aug 29, 2020 09:34 PM
Z Power
Sep 19, 2015 11:19 PM
Fatdog2
Sep 16, 2015 11:04 PM
