Brake Rotor Install
Re: Brake Rotor Install
Originally posted by Red95M6Z28
Does anyone have a how-to for replacing the front rotors and pads? I searched with no luck but then again I have been called retarded before. buhahahaha thanks!
http://www.installuniversity.com/
Good Luck
You'll need a 9/16 allen wrench..... To take of the two caliper bolts.... It's easy once you start @#$%ing with it..... It took me only about an hour to do all 4...... With the stock jack....... Get that install university article.......And don't forget to, Pry the two caliper bolts out ....So it can clear the rotors....... Its EASY.....
Magenta_Hearts
Mar 25, 2015 10:24 AM
jj_burchiel
Mar 21, 2015 12:51 AM
bossco
Nov 29, 2014 10:18 AM
