Brake line routing on a Moser 9" with LT1 brakes.
Has anyone run LT1 brakes on a Moser 9" ? I'm curious on how they ran the brake lines. I would like info and pics (if possible) on mounting the "T" fitting and the two brake line brackets from the caliper brackets. I don't have a reference to look at as mine had drum brakes on a 10 bolt.
The caliper lines seem too short for the Moser unit to use the mounting brackets. And then, I'm guessing you would try to drill on top of the highest bolt retainer for the "T" fitting.
Any help is appreciated.
Thanks,
Terry
Thanks,
Terry
kclarson
Aug 22, 2002 04:04 PM
