brake line flaring kits
Old Apr 28, 2004 | 09:53 AM
QCKZ28's Avatar
im going to delete my abs and traction control modules in the brake system, which flaring kit do you recommend?
SUMMIT p/n SUM-900310 http://store.summitracing.com/partde...t=SUM%2D900310
JEGS p/n 555-80087
http://www.jegs.com/cgi-bin/ncommerc...01&prmenbr=361
thanks
jesse
Old Apr 28, 2004 | 10:05 AM
Brundle's Avatar
which ever one you choose, keep in mind that our brake line connections end in a bubble flare, not a double flare, so you'll need to buy adapter connections if you double flare them. this way they fit properly into the master cylinder, or the brackets where the join into the flex lines
i went through this ordeal when replacing a small section of brake line near the rear end of the car during the winter
Old Apr 28, 2004 | 11:57 AM
HBHRacing's Avatar
they are both the same.. you might wanna look for a kit that does a 37 degree flare, it seems to seal a little better. and I am very very glad that someone mentioned the bubble flare. I have yet to do anything to the lines on my car do I din;t know if they were bubble or standered double flare but you can NOT mix them up. like he said you can make your lines and then use end adapters to be able to link everything up to the stock fittings.
Old Apr 28, 2004 | 10:08 PM
QCKZ28's Avatar
thanks
is there anything to buy to make a bubble flare?
jesse
Old Apr 29, 2004 | 12:03 AM
TW95Z's Avatar
I'm not quite done with the entire write up but here's what I did to remove abs and tcs.
http://www.pharmacy.arizona.edu/staf.../NoABSTCS.html
I used the Performance Tool Double Flare Tool W80670 made by Wilmar Corp and purchased at Sears (under $20 if I remember correctly) to make my flares. I reused the lines out of the master cylinder so I didn't need to make any bubble flares.
I just noticed in Summits new catalog they have a new product 37 degree flare kit which might be good if you go that route. It's certainly cheaper than other 37 degree tools I've seen.
Old Apr 29, 2004 | 02:01 PM
Brundle's Avatar
yes there are bubble flaring kits out there, but in comparison to double flaring kits, they are about 2 or 3 times as much in cost
Old Apr 29, 2004 | 03:55 PM
Bone Daddy's Avatar
When I deleted my ABS and modded my brakes (went from drum to disc) I used s/s AN line and adapters to merge the bubble flare lines to my new layout. Now about 75% of my brake line and fittings are s/s AN. I prefer to have my lines flared at a local shop, as any kit I've ever bought works only about half the time.
Old May 3, 2004 | 10:18 AM
BPS's Avatar
BPS
I just used a couple of swageloc fittings - works fine. Got the idea off a post on the LS1board.
From what I've read the prop box that people install is usually set wide open - that is not reducing the flow to the rears so I did not see the point of adding one - I don't lock up the rears in this set up and the car stops great.
Old May 3, 2004 | 08:18 PM
QCKZ28's Avatar
do you know what size fittings i will need exactly?
my car also has the ASR box and the ABS box, in the ASR box i have two separate lines that goes to the rear of the car, come out as one bigger line and goes into the ABS box.
do i need a tee for the rear lines as well as the front lines?
thanks
jesse
Old May 3, 2004 | 08:23 PM
BPS's Avatar
BPS
Here's the info on the ABS delete.
(1) Swagelok union tee SS-300-3
(1) Swagelok reducing union SS-400-6-3
just a tee for the fronts and a reducer for the rear - should cost about $30 delivered
can't help on the ASR
Old May 3, 2004 | 10:37 PM
QCKZ28's Avatar
that is a great write up, i just am confused on the rear brake lines, tell me how you did yours.
BPS
where is a good place to get those p/n ?
you didnt need a proportioning valve?
what else would i need?
thanks for the help guys, im on a weight reduction frinzy
just removed the entire hvac system last week.
jesse
Old May 3, 2004 | 10:45 PM
BPS's Avatar
BPS
I googled swageloc and found the vendor closest to me and did the transaction over the phone.
from my reading most people who add in a prop valve (wildwood adjustable seems a popular choice) tend to open it up all the way - ie the prop valve does nothing - so I did not bother
here is a poor picture of my setup
http://www.members.shaw.ca/bps-z28/images/misc/!abs.jpg
I also moved my alt which makes things a lot cleaner looking
http://www.members.shaw.ca/bps-z28/i...20relocate.JPG
Old May 3, 2004 | 10:56 PM
QCKZ28's Avatar
AWESOME pics
can i use brass (b) or do i have to use stainless steel (ss)?
jesse
Old May 4, 2004 | 01:10 AM
BPS's Avatar
BPS
stainless is better
Old May 4, 2004 | 01:58 AM
QCKZ28's Avatar
thanks
CARiD
Feb 9, 2015 09:35 AM
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
Azimiut
Jul 22, 2002 05:47 PM
