Best way to get access to rear top shock mount
Old Apr 15, 2006 | 03:05 PM
scanman717's Avatar
So what's the easiest way to get to the top shock mount on an 02 Convertible??? Looks like I might have to remove the upper seat belt mounts, but was hoping someone might have an easier way??
I know my sig shows a 92, that's my car, the 02 is my wife's.
Thanks.
Troy
Old Apr 15, 2006 | 03:24 PM
Lower's Avatar
Re: Best way to get access to rear top shock mount
I would swear that the access was the same for the entire 4th gen.
If so pop your hatch, pull the carpeting up all the way to the back seat, and you should see to foam blocks at each corner in the upper trunk space just behind the rear seat. Pull out the foam and the nut is under there.
Crappy mock up;
http://img109.imageshack.us/img109/3...28trunk5mj.jpg
Old Apr 15, 2006 | 04:25 PM
No hatch to pop on a convertible. The shock mount location is different.
Old Apr 15, 2006 | 04:31 PM
Lower's Avatar
Doh!
I guess once again I should have left the repsonses to the pros!
Thanks for the save Injuneer!
Old Apr 15, 2006 | 05:22 PM
scanman717's Avatar
Yeah, the rear seatbelt mounts are where I think they should be... Guess I will just have to pull them off and see whats under it.
Old Apr 16, 2006 | 03:58 AM
Honda Hunter's Avatar
It's a pita and it's not the same as the coupe. Had to remove the back seat and lots of other stuff to get to it.
Old Apr 16, 2006 | 12:27 PM
Digital Designs's Avatar
some C4 and a prayer should be suffice
87Aerocoupe
Jan 10, 2015 07:27 PM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
