Battery tie down? LT1
Old Jul 31, 2008 | 06:31 PM
78Z28350's Avatar
What do you guys use for a battery tie down on your LT1's? On my stock mount/battery base the front lip that pinches the battery down broke off. What can I use so I don't have to replace the whole base and take off the A/C overflow line? I can't race unless I fix or get a new tie down, until then I'll be using a ratcheting strap tie down. Any help would be great. Thanks
Old Aug 1, 2008 | 12:25 AM
Bud M's Avatar
I bought a new overflow tank, it wasn't that expensive and it was easy to replace. But it would also be easy to fab up a brace that screws to the radiator support in front and the rear clamp mount in back.
Old Aug 1, 2008 | 04:30 PM
NJ-LE's Avatar
Smile
78Z28350:
I used a "universal" bracket (the "I" shaped across the center of the battery type) from the local auto-parts. No need to replace the factory piece ... the lip on a new one is only going to break off again.
Old Aug 2, 2008 | 12:31 PM
Yup... I put a tiny Braille battery in my Formula, and bent up a 1/8" aluminum strap to bolt down to the stock battery clip bolt and the radiator support.
Old Aug 2, 2008 | 05:41 PM
78Z28350's Avatar
Cool guys, I'll either fab up a new front lip or a strap to go over the whole battery with some scrap I got around, or buy a universal one for like $4.
Old Aug 5, 2008 | 04:58 PM
JasonK94Z's Avatar
part # BHFBLK at http://www.yearone.com/
Old Aug 6, 2008 | 09:37 AM
Bud M's Avatar
^ That's pretty much what I had in mind. Should work perfectly.
Old Aug 6, 2008 | 05:29 PM
That part looks exactly like the one I formed out of the 1/8" thick aluminum strap, except mine is polished.
nosliw
Feb 7, 2015 01:30 PM
Gtpguy
Jan 26, 2015 04:50 PM
97z28k&N
Jan 9, 2015 04:58 AM
Hurin
Dec 13, 2014 07:38 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
