Ball joint questions
Old Dec 14, 2004 | 11:39 PM
AlmostfastLT1's Avatar
I am going to install new ball joint this weekend. My question is they are on there way, and i need to know if they are the pressed in kind so if I need to take them to a machinest.
Also, I have the qa1 shocks up front that I am installing and have the springs too, can just any suspension shop compress them and set them on the plates. I heard from one shop that is took awhile and they need to compress the spring very slowly for the qa1 coilovers I have.
Thanks Mark Tisdale
Old Dec 15, 2004 | 01:28 PM
Re: Ball joint questions
ttt
Old Dec 15, 2004 | 03:43 PM
Mikey97Z's Avatar
Nah, man. You can do it all yourself pretty easily. You'll need a balljoint press (just borrow for free from Autozone). Use it to press out the old BJ and carefully press in the new one. Not much more to it than that.
As for the QA1's, you don't even need to have them compressed. Since the spring height is adjustable, you can just turn the adjuster down so far that the spring doesn't need to be compressed to get it installed. Install the shock with the spring on it like that, then start turning it up till you get the ride height that you like.
Old Dec 16, 2004 | 12:16 AM
thanks man, but I noticed that the upper bjs are bolt in and the lowers are pressed in. But anyways man thanks for some info. My buddy has a press that his shop that I am going to use tom.
Mark
Victor Lamb
Aug 26, 2017 02:52 PM
blac94Z
15
Mar 2, 2015 12:00 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
ModdedNerd
Dec 10, 2014 08:42 PM
91 Redd Sledd
Aug 4, 2002 10:47 PM
