Torque arm install Q?
How hard is a torque amr with drive shaft saftey loop to install on a 94 z, auto tranny? Do I need any special tools? Is it the best traction bolt-on? If not what is? I got a whole new suspension but am not wanting to get in over my head by putting everything in at once. What are the easiest suspension parts to install? I have the following parts going on in the near future. Torque arm, bar, sfc, lca, stb, sway bars front and rear? Any thoughts? Which are the easiest to install?
Re: Torque arm install Q?
Sub frame connectors
torque arm
front swaybar
rear swaybar
LCAs
Strut tower brace
You could easily put all of them on, except the SFCs, in a day with regular hand tools. (mostly 13, 15, 18, 21mm, hammer, and a big screw driver to pry with.
