Anyone had a problem w/k-member/a-arms?
Old Jan 1, 2008 | 09:59 PM
mdacton's Avatar
The a-arm sliding in the slots on the k member?
Whats the fix for this?
Old Jan 2, 2008 | 08:27 PM
OBE1 95Z28's Avatar
Mine slid on me (BMR K member and lower control arm). Alignment shop used red loctite and cured the issue.
Old Jan 2, 2008 | 08:32 PM
mdacton's Avatar
it was not an issue of the bolt being loose though.......it was even tight when I had to move it back.
They are sending star washers with the K-members now to grab into the tab....
This is a drag car and it did this when the tires came up then came down again......I'm not taking any chances...I have everything here so I got it all right as far as alignment and I will weld the washers to the tab....If I need to do anything I will just have to grind the weld......But its a sickening feeling having something in question when your going fast.....
I hate to take any chances
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
