alignment done, camber question
Old Apr 14, 2007 | 04:28 PM
Terran2k's Avatar
so i had new tires put on today, so I went ahead and did an alignment as well. on the driver front camber is 5degrees, on the passenger front camber is 3.5 degrees. The guy at the alignment shop said something is bent as they could not correct it on the passenger side. what do you think?
Old Apr 14, 2007 | 08:08 PM
Stock camber is -.4°. You are way off. Something just may be bent.
[edit] sorry, it's +0.4°
Old Apr 14, 2007 | 08:21 PM
Terran2k's Avatar
my fault shoebox, I meant to say CASTER. not CAMBER. what can I do to correct caster?....... the camber is -0.1 left and right btw
Old Apr 14, 2007 | 11:41 PM
If they run out of adjustment, you may have a bent steering knuckle on that side.
Old Apr 15, 2007 | 12:48 AM
Terran2k's Avatar
either they ran out of adjustments or didn't know how to align it. Where is the adjustments for it? I'll take a look @ it amd see of there's any adjustment left before going to a diff shop.
Old Apr 15, 2007 | 09:35 AM
Dave89IROC's Avatar
caster(and camber) adjustment is the lower control arm mounting bolts, the holes are slotted IIRC
Old Apr 15, 2007 | 01:33 PM
mrr23's Avatar
http://www.ls1.com/forums/showthread.php?t=24065
factory spec is +0.40* not negative.
if he can't get the caster up any further, look at the control arm bushings. the rear one is most common for going bad.
for you to have a caster of 5* on the left and 3.5* on the right, the car must be pulling really hard to the right. if not, then maybe his machine is out of calibration.
Old Apr 16, 2007 | 11:16 PM
I inadvertently put the negative sign in there. My bad.
Old Apr 17, 2007 | 01:53 PM
Terran2k's Avatar
It is pulling to the right, not really hard but it is pulling to the right. I will look to see if there's any adjustment and check the bushings.
I have a few problems with my car as of late, if my other problems are related to sticky calipers, I will upgrade to LS1 front brakes. i've wanted to do it for a while and might as well do it if I have to replace these things. that way I can get the calipers, steering knuckle and bushings changed out all at once.
oldschool
Feb 9, 2016 09:21 PM
dfarr67
Apr 10, 2015 07:44 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Noenav
Dec 6, 2014 07:35 PM
