Alignment after k-member and A-arms
Old Feb 12, 2007 | 06:46 PM
mdacton's Avatar
anything special I should do or set eveything to stock specs?
This is a drag only car, and I run front runners on it on a 3.5" wheel.....any tricks to the alignment?
Old Feb 13, 2007 | 09:37 AM
OBE1 95Z28's Avatar
I have the BMR K member and found that the lower control arm alignment bolts came loose after the first alignment. Took it back to the alignment shop and they ended up using red loctite on the bolts to keep it tight.
Old Feb 19, 2007 | 07:32 PM
NOSCaMaRo's Avatar
Aftermarket K-members do not have "teeth" in there lower A-arm mounts like the factory k-member does. This can cause the A-arms to shift easier and ecspecially when you hit a bump. So make sure the a-arm bolts are extra tight!
97blackformula
Aug 27, 2015 06:02 PM
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
Koby
Jun 28, 2015 04:46 PM
ShaneS
West South Central
Sep 11, 2002 07:48 AM
Wilson
Jun 19, 2002 07:27 PM
