ABS Removal (Flaring)???
Old Sep 19, 2004 | 10:58 PM
Camaro4LifeSS's Avatar
I'm getting ready to remove my ABS unit and I had a few questions before I start.I've read a few posts about people having a hard time reflaring the rear brake line.I would like to cut and reroute the rear line without replacing the whole line if possible.I have a good Snap-On hydraulic flaring tool and I was wondering if that would make it any easier?Has anybody sucessfully reflaired the rear brake line?One more,what kind of flare does the lines going into the master cylinder have?
Thanks,
JE
Old Sep 20, 2004 | 07:04 AM
Re: ABS Removal (Flaring)???
Bump
Old Sep 20, 2004 | 12:13 PM
Nobody has any info on this?Is their something i'm doing wrong?I can't seem to get many replies from any one anymore.I'm in need of help and I usually get all my info here.Any help would be nice.
Thanks,
JE
Old Sep 20, 2004 | 01:49 PM
Z95m6's Avatar
Why are you removing your ABS anyways?
Old Sep 20, 2004 | 03:06 PM
WS Sick's Avatar
Heres a pretty good thread.
http://web.camaross.com/forums/showt...light=Brady96z
Old Sep 20, 2004 | 04:17 PM
I bought a Moser 9" thats the reason i'm dumping it.
Thanks for the link WS Sick.
JE
Old Sep 20, 2004 | 05:21 PM
Z95m6's Avatar
Just make your own ABS set up and keep it. Thats what i did on my 8.8 3 channel car. It works great now.
Old Sep 20, 2004 | 09:08 PM
I'd rather get rid of the ABS.It sure does clean the engine bay up and I never drive in the rain so I really don't think I will need it.
Thanks,
JE
Old Sep 21, 2004 | 04:33 AM
8850's Avatar
My car is an LS1 but this is how I did mine. http://www.mustangmods.com/data/440/absdel.jpg
I would be careful using brass fittings unless they are specifically designed for brake systems. The fittings I used are Swagelok stainless steel high pressure fittings.
Old Sep 22, 2004 | 04:40 PM
LJ93Z28GM's Avatar
I posted to your other thread as well. I deleted my ABS as well, I posted a pic and info in a few of my posts on how to do it. 40 valve, 2 dollar tee and a couple of fittings and it is all good.
Old Sep 22, 2004 | 05:28 PM
Hey 8850,were did you get your braided brake lines?I like those.Is that recommended to use braided lines off the master cylilnder.I would'nt think so because the same line is at the wheel.I thought of doing that the other day but I thought maybe there was something against useing them cause I never seen anybody else with it.
Thanks fellas,
JE
Old Sep 22, 2004 | 08:38 PM
8850's Avatar
Thanks fellas,
JE
The braided lines you see are my factory lines. Apparently on LS1's they changed.
Old Sep 22, 2004 | 08:50 PM
Oh ok,anybody know where I might find some?
Thanks,
JE
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Boss002
Jan 20, 2016 12:17 PM
ducttape1975
Jul 10, 2015 06:29 PM
CARiD
Jul 7, 2015 08:19 AM
