Abs Inop Light .....help
HEY ALL BESIDES THE DEALERS WHO ELSE CAN SCAN MY 94Z ADVANCE ?? AUTOZONE??? AND FIND OUT WHATS KEEPING THE ABS INOP LIGHT ON? IT'S DRIVING ME NUTS, SOMEDAY'S IT COMES ON SOMEDAY'S NOT. WHEN IT'S OFF IT SOMETIMES COMES ON GOING DOWN THE ROAD TOO ARGHHH HELP
Re: Abs Inop Light .....help
Originally Posted by Smith4046
Just an outside chance - check your third brake light to see if it is still functioning. Apparently many things can set off that ABS light.
Best of luck.
Steve
Best of luck.
Steve
werd
A third brake light bulb being burned out will throw the light. AND QUIT SCREAMING PLEASE.
Also check to make sure the cables around the positive battery terminal (where that red plastic cover is on the shock tower) are all tightened down and free from corrosion. Mine was loose and I tightened it up and it fixed the problem.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
